Can I use FME to combine 2 las files classifying las_01 as ground and las_02 as surface?
  • February 27, 2017
  • 125 views
I have been given 2 las files. One for ground points, and one for Surface points. I would like to combine the files into one in order to utilize the lidar classes for presentation purposes.
  • February 27, 2017
Hi @robertdbuckley, I think you can do that with the PointCloudCombiner transformer.
jdh
Forum|alt.badge.img+28
  • February 27, 2017
Agreed, you can use the PointCloudCombiner to merge the two files. If the individual point clouds do not have a classification, then you can add it as a component using the PointCloudComponentAdder prior to the PointCloudCombiner.
