I have a workflow that needs to bring data from an ESRI geodatabase, do some standard transforms, run a complex Excel model, and summarise in a final Excel output. Clearly FME will write to the model input sheet. But can I get FME to run the model as if it was a transformer, then pull the results out to the final summary? Thank you.
Can I run a complex Excel model as a transformation?
