Can gINT (.gpj) files be read into FME? If not, are there workarounds? If not, are there any future plans to add it ?
  • August 6, 2020
  • 29 views
Best answer by mark2atsafe
In answer to your questions:
  • No, there is no specific gINT (gpj) reader or writer in FME
  • Yes, I believe the files are based on Access, so you could use the Microsoft Access format to read the file contents
  • No, I don't see any plans. The best thing to do is file this as an Idea on this site, then any other users with the same interest can vote up the request and it will get noticed by the product managers at Safe
I hope this helps. If you can't get the workaround working, then please do let us know.
mark2atsafe
Forum|alt.badge.img+44
  • August 6, 2020
