Can FME Desktop accesses ArcGIS server map service as a reader?
  • February 18, 2014
  • 14 views
aguan
Forum|alt.badge.img+11
  • February 19, 2014
there doesn't seem to be a dedicated reader, but since the map services are available from a REST-based API (http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#//02r3000000w2000000), you can still easily access them using the HTTPFetcher or the ImageFetcher transformers.
David
aguan
  • February 19, 2014
Thaks, David, I may give it a try.
