Bulk renaming of feature datasets in an SDE database?
  • Jul 2, 2019 2:05 PM UTC
  • 170 views
I am new to FME desktop, so i understand that this question may be already answered or that i have missed the right transformer due to my unfamiliarity/noobiness.
Context: I am in the final stages of converting a combination of arcgis model builder, python and SQL processes that result in 15 "_new" datasets being produced and outputted into an SDE database (a weekly process - In FME i am working with full file replacements and not merged/replaced data.). The final step is to have the 'new' datasets become the 'current' datasets, and what is known as the 'current' data to become the '_old dataset (i.e. back up).
Currently the update (renaming) of these datasets into production is done manually (not ideal), so i am aiming to speed up the renaming and reduce the chances of human error.
In essence each of the 15 datasets in the database has a total of 3 datasets related;
  • '_old' = previous weeks data kept as back up
  • current data which has no _suffix, and
  • '_NEW' = updated/new data (that needs to replace the 'current' data)
Question: is their a way that i can bulk update/replace/rename the datasets (not their attributes) in FME so that;
1) all '_old' gets deleted (e.g. 'address_old.shp')
2) all '<current>' get renamed to '_old' (e.g. 'address.shp becomes 'address_old)
3) all '_NEW' get renamed to '<current>' (e.g. 'address_NEW.shp)
I can use python caller and write a script to do the renaming, but i was hoping to keep everything within FME. Does anyone have any suggestions :)
@courtknee82 I think a combination of the Directory and File Pathnames Reader and the File Copy Writer should do the trick. There's an example workspace here.
The shape files i am trying to rename as well as the output location are within an SDE database. I didn't think either of the Directory and File Pathnames Reader and the File Copy would work as when i go to connect neither recognise the path location of the sde (assumed this was because it wasn't a 'folder/file' format.
@courtknee82 someone with more SDE experience will have to help. I'm not sure how SHAPE files can be stored in an SDE database
  • Jul 11, 2019 12:54 AM UTC
That's ok. Thank you for your help in any case.
