Build shapefile indexes with generic writer
  • May 23, 2019 6:33 PM UTC
  • 122 views
tris_w
Forum|alt.badge.img+8
I'm using a dynamic workspace with generic writer to create output files in the format that the user selects. When the user chooses to export as ESRI shapefile I would like it to also build the spatial indexes for the output shapefile. I can get it to write the shapefiles just fine but they don't have spatial indexes. Is this possible with the generic writer by setting it in the schema feature somehow? Or would I have to specifically use the shapefile writer which has it as an option?
jdh
Forum|alt.badge.img+41
  • May 23, 2019 8:18 PM UTC
If you add a shapefile writer, don't connect it to anything, and set the spatial index to Yes on that writer, then the Generic Writer will also use that setting when writing shapefiles.
tris_w
  • May 23, 2019 8:49 PM UTC
Thanks, that would have been neat if it had worked... but it doesn't create the indexes for me. I have a dummy shapefile writer in the workbench with the Create spatial index set to "Yes".
jdh
  • May 24, 2019 1:42 PM UTC
That works for me with a featureWriter set to the generic format, a regular shapefile writer, in FME 2018 and 2019.
What version of FME are you using?
