Build 3D Line using x,y,z text file
  • May 8, 2024 6:30 AM UTC
  • 7 replies
  • 236 views
offi24
I have a .csv file with x, y, z coordinates. From these points, I want to create a 3D line. Currently, I have the issue that the z coordinates are not being transferred onto the line when I create a line from the points. Does anyone have an idea of how I can proceed?
Best answer by nielsgerrits
This works as expected. You see only one attribute because you set Accumulation Mode to Use Attributes From One Feature. But the actual 3d coordinates are in the line you see in the Graphics window in Visual Preview. If you want to keep all coordinates, check the Generate List box and configure it.
nielsgerrits
Forum|alt.badge.img+67
Multiple ways to do this.
One way is to read the CSV, define x,y,z colums as x,y,z coordinate. Then use a LineBuilder to connect the points.
Other was is to read the x,y,z as text, use a VertexCreator to create points from x,y,z, then the LineBuilder.
offi24
  • May 8, 2024 7:02 AM UTC
The issue is that when I do this, the z coordinates of the line are lost in the “LineBuilder”. So the line only takes the z-coordinate of the start, and the remaining data as well as the third dimension are lost.
nielsgerrits
Not sure if I understand your issue. These steps produces 3D points and then 3D lines.
Can you share a sample of your data? Then I’ll create a workspace demonstrating this.
offi24
  • May 8, 2024 7:24 AM UTC
The input data looks like this. I cannot share the entire dataset with you, sorry. My script in FME is looking like this.
Thanks for your help
nielsgerrits
offi24
  • May 8, 2024 8:35 AM UTC
Perfect, it works. Thanks for your help
nielsgerrits
Cheers :)
