Bringing in Data for past 30 days from SQl server using SQL to run before read
  • November 3, 2017
  • 224 views
Hello I am new to FME and I am trying to bring in spatial data from SQL server by adding where clause in the reader using function "SQL to Run before Read". I am not sure what query do I use?I am using the following statement but it is giving error.
select * from SDEDBO.Services where Date>=Dateadd('day', GETDATE(),-30)
thanks for your help!
Best answer by david_r
You should probably use the "WHERE clause" setting and not the "SQL to Run before Read":
  • November 6, 2017
  • November 6, 2017
Looks the syntax for the Dateadd function is wrong. Check here: DATEADD (Transact-SQL)
I think the WHERE clause should be:
Date >= Dateadd(dd, -30, GETDATE())
  • November 6, 2017
Where clause worked with this query
Thank you for your help!
