BlueCielo Meridian reader/writer
  • Oct 2, 2017 4:02 PM UTC
  • 72 views
I know that there is currently a Bentley ProjectWise reader/writer in the works. Is there any plan to create a BlueCielo Meridian reader/writer as well? May be a difficult task, as many instances of Meridian are built on a proprietary object orient database called Hypertrieve. Maybe some clever user can come up with some custom transformers to access the Meridian api...
Best answer by trentatsafe
Hello, @mrmartinstreet,
There currently are no BlueCielo format readers on the FME Hub, however, this sounds like a great idea! You could post your idea over on https://knowledge.safe.com/content/idea/list.html
This would allow other users to upvote your idea and bring this idea to the attention of the developers. Often times, the developers use the ideas board as a place to start when looking at adding new formats and functionality to FME.
trentatsafe
Forum|alt.badge.img+7
  • Oct 2, 2017 4:51 PM UTC
