Black Multipatch Features
  • Nov 18, 2015 2:00 AM UTC
  • 12 replies
  • 190 views
jackyd
Forum|alt.badge.img+16
HI,
I am copying Multipatch features from one file GDB to another, but when i do this they rendered and solid black features when viewed in ESRI
This
Instead of this
Any thoughts on what is happening?
Thanks
Jacky
Best answer by nielsgerrits
I understand this is an old topic, but for documentation: Adding the AppearanceRemover solved my problem.
mark2atsafe
Forum|alt.badge.img+59
Can you read both before and after datasets into the FME Data Inspector, then look at the attributes and geometry in the feature information window? That might give you a clue as to what is different in the output.
gio
Forum|alt.badge.img+15
  • Nov 18, 2015 4:29 PM UTC
Maybe the normals are inverted? in x,y plane?
jackyd
  • Nov 19, 2015 1:16 AM UTC
Thanks for the tip, how do i check the normals?
jackyd
  • Nov 20, 2015 12:18 AM UTC
Thanks Mark,
I have had a good look and cannot see any differences between the features.
mark2atsafe
Thanks Mark,
Then I'd suggest sending that into the support team (safe.com/support) including the data and workspace and asking them for assistance. There must be some difference but I'm afraid I don't know off hand what it could be.
mark2atsafe
Oh, try the GeometryValidator - it might be able to detect bad normals or missing texture coordinates. Not certain it will help, but worth checking it out.
ola
Participant
  • Participant
  • Feb 9, 2016 3:11 PM UTC
I'm sorry to say that I don't have an answer to this problem, instead I have the exact same problem. The output between geodatabases (file, personal, and sde) are pitch black multipatches (that stay black even after exporting to other formats like Sketchup). Running the GeometryValidator does not fix the data. Writing to shape-format works, however... Where you able to find a solution for this, or did you figure out what the problem is @jackyd?
nielsgerrits
Forum|alt.badge.img+67
bgeorges
  • Apr 20, 2022 5:43 PM UTC
That solved my problem with the black multipatches
nielsgerrits
You provide some interesting knowledge. It helps me alot.Thanks for giving this information.
  • Sep 5, 2023 11:44 PM UTC
This works for me
