Batch Deploy won't write to ArcGIS online
  • Feb 21, 2020 9:35 AM UTC
  • 5 replies
  • 95 views
anders_d
When trying to Batch Deploy my simple Geopackage files to AGOL the 'Next' button never gets possible. It wants a path to the files to be written. Is it not possible to use Batch Deploy to upload to AGOL or what am I missing?
Best answer by rahulsharma
Hi @anders_d,
Unfortunately, Batch Deploy is a bit old now, as it is from a time when FME was mostly Files and folders data types and no Web Services were involved. That is most likely the reason why the "Next " button is disabled ( I can investigate this with our dev team).
Workaround
In your case, the best solution is to use Workspace Runner solution which will have 2 workspaces
1. Control Workspace (Pass the name of each file)
2. Processing Workspace (upload the data to AGOL)
This article is good start point https://knowledge.safe.com/articles/1469/batch-processing-using-the-workspacerunner-1.html
rahulsharma
Forum|alt.badge.img+12
Hi @anders_d
You can use Dynamic and Write for both Geo package and AGOL to upload data
For ArcGISONLINEFEATURE write, set the following feature type properties
Select "Dynamic Schema Definition"
Geometry should be set to "From Schema Definition"
Schema Source: "Schema From Schema Feature"
anders_d
  • Feb 24, 2020 8:04 AM UTC
Hi @anders_d
I have no problem running the workspace. It's the Batch Deploy that won't be setup and saved.
rahulsharma
Hi @anders_d,
Workaround
rahulsharma
  • Feb 24, 2020 7:20 PM UTC
Hi @anders_d,
Workaround
anders_d
  • Feb 25, 2020 10:35 AM UTC
Hi @anders_d,
Workaround
Great! I made it work with the Workspace Runner as controlling.
Thanks for the guidance.
