Hello,
In the Text_File writer I cannot select an attribute I've just created
How can I solve that?
Best,
Harmen
Hello,
Best,
Harmen
Best answer by david_r
The text file writer only has one attribute "text_line_data", you cannot add others.
For each feature sent to the writer, the value of "text_line_data" will be output on a separate line, all other attributes are ignored.
