Bad SRID convert while converting postGIS to oracle spatial
  • November 14, 2017
  • 55 views
I have a GIS application using postGIS database . For some reasons i have to migrate from postGIS to oracle . And i got familiar with your awesome software
Migrating from a shape file to oracle is all right but when i am trying to convert data from postGIs to oracle, i have issues in converting geometry data , actually the source SRID is 4326 but when the convert is done , the geometry column is not in the right SRID and GeoServer is unable to load geometry data .
I tried different methods in converting data such as
1- select SRID from source and
2- using EPSG 4326 on Oracle writer SRID but i still have the same problem
Best answer by mandinariman
the problem solved
i find out that my postgis source data was in 900913 format that is not an official format of SRID and this is why FME Software couldn't convert properly
i converted my geometry data to 4326 format using script below
update planet_osm_roads set way = ST_Transform(way, 4326)
and now when i convert my postgis to oracle by FME everything is all right.
erik_jan
Forum|alt.badge.img+22
  • 2179 replies
  • November 14, 2017
The best way of doing this is inserting a record for the table in the MDSYS.USER_SDO_GEOM_METADATA table in Oracle, containing the right SRID.
If you create the table using FME, you can do that using the parameters section on the table.
  • December 25, 2017
thanks dear @erik_jan
yes i can set SRID to 4326 and the SRID section of geometry data will change from null to 4326 like data below
before:
{2002,4326,null,{1,2,1},699956.85,3853005.3,5700031.07,3852978.66,5700057.01,3852973.81,5700069.08,3852975.18,5700082.09,3852980.66,5700092.13,3852987.72,5700099.65,3852995.49,5700105.59,3853004.61,5700110.37,3853017.6,5700110.83,3853031.29,5700106.04,3853042.69,5700096.69,3853055.02,5700078.43,3853068.69,5700010.33,3853109.78}}
after
but the problem is in vector data that doesnt't seem to be converted correctly cause i know the correct format of 4326 is like sample below
xx.xxxxxxx
  • December 26, 2017
the problem solved
