Avoiding SDE spatial index creation
  • Jun 1, 2018 6:12 PM UTC
  • 183 views
_trent
Is it possible to write annotation features to an ArcGIS SDE annotation feature class without a spatial index being created in FME?
I am writing annotation features to ArcGIS SDE on SQL Server using the GEODATABASE_SDE writer. I delete the spatial index on the target annotation feature class before running FME. I do not want a spatial index created on the feature class, but FME appears to always be creating one. Referencing this article I have tried the below FME and SDE settings, but the result is always the same.
Environment:
  • FME 2018.0.1.0 (20180518 - Build 18310 - WIN32)
  • ArcGIS Desktop 10.2.1
  • ArcSDE 10.2.1
  • SQL Server 2014
Feature Type Grid 1 Value
SDE LOAD_ONLY Mode
Spatial Index Created
unset/blankYes
Yes
0
Yes
Yes
-1
Yes
Yes
unset/blank
No
Yes
0
No
Yes
-1
No
Yes
lars_de_vries
Forum|alt.badge.img+10
Looking at this thread, that is referenced from the page you mention, it seams as if it is not possible to not create a Spatial Index unless you're writing to Oracle.
_trent
  • Jun 4, 2018 4:07 PM UTC
Maybe. Since I'm using the GEODATABASE_SDE writer in FME I wasn't sure if that referenced page applied, as it deals with the SDE C API.
Using the ArcGIS geoprocessing modules, though, I can run an Append from a file geodatabase to SDE and the spatial index isn't created. So it seems like this should be possible in ArcObjects, which I assume is what FME is using under the hood.
lars_de_vries
The only thing I can find about the Grid 1 Value, is that it only needs to be set when creating new feature classes, since in all other situations the grid already is present. Bottom of this page, it is mentioned a second time on this page. The first is about Feature Type parameters and the second about Writer parameters.
Sorry I can't help you any further. I no one responses I would contact your reseller to file a question there.
