Automate updating documents on CDE
  • Apr 6, 2020 12:43 PM UTC
  • 70 views
chrbalm
Forum|alt.badge.img+8
I am currently updating a number of documents and models on a CDE (currently trying to pull the API information) that require manually logging into the system as an administrator, deleting the files in question and then uploading the updated file.
I wanted to see if there was a way to automate this procedure through an FME workbench?
itsmatt
Forum|alt.badge.img+48
  • Apr 6, 2020 1:46 PM UTC
I suspect if you get the API then this should be pretty doable with the HTTPCaller. You might have to use a few in a row depending on how the authentication works for the server.
You can use PostMan to test you queries and then use FME to automate them.
chrbalm
  • Apr 6, 2020 5:24 PM UTC
Thanks. The HTTP caller seems to be able to identify each document, but still trying to identify how FME can automate the downloading of these?
