autocad_viewport_view_center_x,y and autocad_viewport_twist_angle not working together
  • November 11, 2019
  • 10 views
I have a workspace in which I create a viewport and then center the model space over specific coordinate, this works great, until I try and twist the viewport, then I only get viewport twist and no centering or scaling of the viewport, is there an attribute order I am not respecting? I really need to focus the viewport and twist it.
Here are the transformers I am using to create viewport and calculate twist angle.
Here are the attributes I am creating with the attribute creator.
And I am getting center of location in model space units from CenterPointExtractor
This works great to get the viewport centered on a specific location, as soon as I add this
I lose the location inside the viewport and all I get is twist angle in the viewport no custom scale or focus on x,y. Anyone have a similar issue?
Here is viewport with autocad_viewport_twist_angle set, the rotation of viewport is good, but no focus
And once I remove the twist angle attribute I get this, the viewport is center perfect.
How do I combine these behavior successfully?
Below is link to workspace.
jovitaatsafe
Forum|alt.badge.img+11
Hi @garydlester,
I'm not 100% sure here, but this previous Forum question suggests that the order of attributes is important and changing that seemed to work for them. I think the autocad_twist_angle may need to be last in your AttributeCreator/Manager after you have set the center of the view. There's a bit more on Viewports in this documenation.
Hope that helps a bit!
