AutoCAD Viewport Scale
  • Oct 22, 2019 11:22 PM UTC
  • 136 views
deanhowell
Forum|alt.badge.img+24
I am trying to work out the actual scale of the viewport(s) in AutoCAD DWG to make sure they conform to a particular scale.
Attached is an example DWG that I am trying to determine the scale of the viewport.
Any assistance would be greatly appreciated.
Regards
Dean
Best answer by becchr
Hi @deanhowell,
I'm pretty new to FME, but had the same question on one of my projects too. Maybe there's a more elegant way but this worked for me:
  • in the dwg-reader make sure you read the paper space and select the layouts you want the viewports to read from:
  • in the reader group by 'geometry' so you can select just the viewports as feature types and expose the format attributes 'autocad_viewport_custom_scale' and 'autocad_space'
  • depending of the drawing units and layout units you can calculate a traditional "1:X"-scale
Hope this can help you? I attached the workspace with your dwg (i changed and added some viewports just for testing)
acadvpscale.fmwt
becchr
Forum|alt.badge.img+35
  • Oct 23, 2019 8:40 AM UTC
Hi @deanhowell,
acadvpscale.fmwt
deanhowell
  • Oct 23, 2019 9:34 PM UTC
Hi @deanhowell,
acadvpscale.fmwt
Thanks @becchr, I appreciate the assistance. That is exactly what I need.
