AutoCAD to KMZ hyperlink attribute
  • Oct 2, 2017 3:00 PM UTC
  • 14 replies
  • 169 views
I am new to FME, need some help please.
I need to convert AutoCAD dwg with some polylines and text into KMZ. Text includes hyperlink to .dst (dataset) file.
How can I include hyperlink in KMZ file?
Thank you !
danilo_fme
Forum|alt.badge.img+58
  • Oct 2, 2017 3:06 PM UTC
Hi @klika68,
Could you share a sample of your DWG?
Thanks,
Danilo
  • Oct 2, 2017 3:14 PM UTC
Here is Autocad file. As you can see, any SR*** text has hyperlink to .dst file that is stored on local drive.
index-map-sample.dwg
danilo_fme
  • Oct 2, 2017 3:24 PM UTC
Thanks your data. I opened in FME Data Inspector and selected the text from feature type SR31-1708.
How you can see the attribute extended_data has the information your local files dst.
My question: For now do you want to red theses values from extended_data and convert into KML?
Thanks,
Danilo
  • Oct 2, 2017 3:32 PM UTC
Hi Danilo, thanks for your reply.
Yes, I want to covert it to KMZ so both lines and text are included and also hyperlink is preserved in KMZ file so I can open .dst file.
Thank you
danilo_fme
  • Oct 2, 2017 4:40 PM UTC
Thank you
Perfect. Could you say that system coordinate is your dwg file? I need to set before write KML.
Thanks,
Danilo
  • Oct 2, 2017 4:48 PM UTC
Hi Danilo,
AutoCAD drawing has no assigned coordinate system, you can just leave it as is/unkwown.
For Google earth/KMZ file the best bet is to go with either WGS84 or LL84, they are very similar.
Thank you
danilo_fme
  • Oct 2, 2017 5:12 PM UTC
Hi Danilo,
Thank you
Hi @klika68,
I generated the kml final and stored the attributes in dst_local1 and dst_local2:
I used the transformer AttributeExposer to enable the format : attribute autocad_extended_data_list
Workspace attached.
Thanks, - workspace-dwg-to-kml.fmwt
Danilo
  • Oct 2, 2017 5:46 PM UTC
Hi Danilo,
unfortunately that`s not what I need. I can see SR*** text with attributes but there is no any links to .dst What I need is an option to click on the SR*** text and .dst hyperlink and open that file.
Thanks
danilo_fme
  • Oct 2, 2017 6:42 PM UTC
Hi Danilo,
Thanks
Hi @klika68,
I understand you now your request. So, needs to create a attribute like a link.
In transformer AttributeManager i renamed this:
And after used a transformer AttributeCreator to create new Attributes: Hiperlink1 and Hiperlink2:
Has a interesting link about a similar case: Open a PDF Document from a kml feature.
Thanks,
Danilo
danilo_fme
  • Oct 3, 2017 1:14 PM UTC
Hi @klika68,
Thanks,
Danilo
Hi @klika68,
Did you have a good results?
Thanks,
Danilo
  • Oct 3, 2017 1:37 PM UTC
Hi Danilo,
it does not work for me. I am confused. Why do you have to rename output attribute in Attr. Manager?
Would you be able to send me a workflow?
Thanks
danilo_fme
  • Oct 4, 2017 2:09 PM UTC
Hi Danilo,
Thanks
Hi @klika68,
Attached the Workspace Template and the result inside KML file:
I
I configurated the AttributeManager to create the values like Links.
Thanks, - workspace-dwg-to-kml-04102017.fmw
Danilo
  • Oct 24, 2017 5:55 PM UTC
Hi @klika68,
I
Danilo
Hey Danilo,
is it possible to replace STRING to FILE using StringReplacer or maybe some other option? I am not sure how to do it. The link with STRING does not open in AutocAD but works with FILE instead.
<th>dst_local_1</th>
<td><a href="string:\\\\van-fps\\groups\\Engineering\\Technical Records\\Vancouver_Common\\AutoCAD Sheet Set\\Fibre\\SR\\SR14827-3678\\SR14827-3678 [VW07175].dst"> Open</a></td>
Thank you very much for your help!
danilo_fme
  • Oct 24, 2017 7:24 PM UTC
Hey Danilo,
Hi @klika68, its good to listen that its works!
