AutoCAD Map 3D : Duplicate attributes when exporting points entities to Block with OD
  • Oct 15, 2018 1:09 PM UTC
  • 114 views
arxit
Forum|alt.badge.img+5
Hi everyone,
I'm exporting GIS point data to AutoCAD Map 3D DWG file. On output, I need to have the inserts as blocks and the original attributes as object data. In the workflow, I use the "DWGStyler" transformer with block definition defined in a DWG Template file - original block doesn't have any attribute - and output them in AutoCAD Map 3D Writer with OD.
Everything is fine : when I open my output DWG File in AutoCAD Map 3D, I have correct blocks and object data... but block attributes too ! So, I get duplicate attribute information for each object (cf. attachments).
This DWG File must be edited by other users and re-import later on GIS, so the duplicated information can be a source of confusion.
Is there a solution to insert block without block attributes ?
Thanks for help !
arxit
  • Oct 16, 2018 1:06 PM UTC
Sorry for the duplicated post, I've just seen ddecoene post "creating autocad blocks with object data"... with the same issue. I had looking for tomorrow but...
So i try to follow this.
jovitaatsafe
Forum|alt.badge.img+11
Hi @arxit,
just wanted to check in if ddecoene's post answered your question or if you're still seeking an answer?
