AutoCAD file to skatchup
  • Nov 11, 2014 10:14 AM UTC
  • 31 views
Dear all ,
We are using GeometryPropertySetter to set the skatchup file to be in different layers but it doesn't works , we also tried fanout but we got different skatchup file instead of one file with different layers . we exposed the autocad layer name and added to GeometryPropertySetter but again all in vain , any help would be appreicated . Thanks in advnace
  • Nov 11, 2014 3:43 PM UTC
See this: http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000ce3MAAQ
If you still have problems, redirect the writer to the Inspector and double check the geometry traits here, in particular "sketchup_layer_name".
Also consider opening a multi-layer Sketchup file using the FME Inspector and compare the geometry traits there with what you're getting from your workspace.
David
