Autocad Color
  • February 27, 2014
  • 11 views
i am trying to transform Oracle to Autocad.  I need to set some line to a user specifed color.
the color is in RBG and not a autocad color index number.  How would I go about doing that?
Can I substitude autocad_color with fme_color?
fmelizard
Forum|alt.badge.img+18
  • February 27, 2014
If you point to the fme_color in the DWG Styler I think you will be good to go.
  • February 27, 2014
That did the trick.  this was an old workbench before the DWG Styler.  I think I better take a closer look and update this workbench.
