assign variable for excel sheetname
  • Mar 22, 2018 10:09 PM UTC
  • 61 views
I am reading in shape file and using attributepivoter to calculate stats. I then write the results to a separate excel sheet for each source file. After the attributepivoter I can no longer assign the source filename (fme_basename) to the sheet name in the writer
f.kemminje
Forum|alt.badge.img+11
  • Mar 23, 2018 6:19 AM UTC
Hi Richard,
Before attributepivoter save the attribute (fme_basename) to variable using variable setter then again retrieve this variable using variable retriever just before writing.
this will work+
