Assign RGB from attribute to point cloud
  • Jun 12, 2020 1:49 PM UTC
  • 164 views
wilczekmj
Forum|alt.badge.img+4
I have X,Y,Z,R,G,B txt file that I want to convert it to RGB coloured point cloud.
The Point cloud creates fine, however without RGB colour assigned to points.
How to assign RGB values to point cloud based on attributes?
Any help much appreciated.
Thanks,
M
Best answer by jdh
How are you creating the point cloud? In the pointCloudCombiner there is a section on preserving attributes as components. The RGB attributes should be named color_red, color_green, color_blue.
jdh
Forum|alt.badge.img+41
  • Jun 12, 2020 2:54 PM UTC
wilczekmj
  • Jun 12, 2020 3:26 PM UTC
Many thanks jdh,
I used PointCloudCombiner yes but missed the preserving attributes part. Followed your suggestion and it all worked a trick.
Great support!
Thank you
