ArcGIS Server map service cache
  • Aug 23, 2018 8:58 PM UTC
  • 178 views
philippeb
Forum|alt.badge.img+23
I have services into ArcGIS Server with the cache enabled.
I use it as my basemap into applications, it is super fast, cuz it's tiled.
Can I view those tiles into FME?
When I try to read the service with Data Inspector, I only see the vectors, without the symbology! And it takes an eternity to read! The tiles are created from millions of vectors.
I'm using the usual link from ArcGIS Server : http://MyServer/arcgis/rest/services/MyBasemap/MapServer
Got an idea? Or it is impossible right now?
This is my closest scale.
rahulsharma
Forum|alt.badge.img+12
Hi @philippeb, As per my understanding you should be able to use WMS format to read the data and it should bring the map as an image.
Format -- WMS(Web Map Service)
Dataset -- URL (from ArcGIS Server WebMap service)
Layer List -- <Pick your layer>
Parameter --> Map Options --> Output Format -- image/png (optional)
philippeb
  • Oct 25, 2018 2:20 PM UTC
Hi thanks for your answer!
Your method is working but the resolution is very bad! Layers are very pixelised. Do you think there would be a solution to upgrade that?
Second thing, the WMS can be read into FME only if the service isn't cached. I would have to recreate my basemap service without cache... is that normal?
rahulsharma
Hi Phillip,
There are definitely some restriction on the image quality and Tiling, but if you can access your add in another way as a PNG/JPEG (or any raster) it would be much easier to read with full quality.
It appears that the quality of the image on ArcGIS Server is as such, Using sample URL (seen below ) with HTTPCaller and JSON Fragmenter
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapServer/export?bbox=-115.8,30.4,-85.5,50.5&bboxSR;=&layers;=&size;=800,600&imageSR;=102004&format;=gif&transparent;=false&dpi;=&f;=pjson
Note that the image is stored at http://sampleserver1b.arcgisonline.com/arcgisoutput/_ags_map7d1720b91b734fe3b2f8d5cec6fdeb13.gif
Quality of images generated on ArcGIS Server is not the highest quality.
The only other option get all details is to use ArcGIS Server FeatureService to read the actual vector data, but that doesn't seem to be a viable option.
