ArcGIS Portal Feature Service Connection
  • March 13, 2020
  • 21 views
mhab
Forum|alt.badge.img+10
So I need to admit I am absolutely lost in an attempt to use a connection for an existing ArcGIS Portal Feature Service.
I have spent hours to find my way to create a connection for the parameters I need in order to access an existing ArcGIS Portal Feature Service and I fail miserably. I get lost in dialogs where I feel like I need to learn Web development instead of just saving the infos I need in order to use it later on.
The Information I have and I need to access the existing portal Feature Service is:
  • Url
  • Feature Service
  • method
  • user
  • password
... and instead of allowing me to save a connection with these parameters I am sent on a journey through Feature service templates where I don't have the slightest idea what I need to input.
This kind of frustrating adventure is absolutely normal for too many tools out there, but I am not used to this from my long time FME experience.
Where have I lost my way ? And please don't come up with details like REST call so and so ;-(
Heeelp
Michael
rahulsharma
  • March 13, 2020
Hi @mhab, ArcGIS Portal Web Connection is a bit tricky
I have put together instructions here (my comment) https://knowledge.safe.com/questions/109164/failing-to-connect-to-esri-arcgis-portal.html
I hope it helps!
bruceharold
Forum|alt.badge.img+19
  • March 13, 2020
I hope it helps!
...and here is my Data Interoperability flavor, because it's Friday:
https://community.esri.com/community/open-platform-standards-and-interoperability/blog/2020/03/13/creating-a-web-connection-for-your-portal-in-data-interoperability-or-fme
