ArcGIS Online Feature Writer 404 Client Error
  • Nov 20, 2017 11:15 PM UTC
  • 97 views
kieranodonnell
Participant
Hi all,
I'm trying to overwrite a Hosted Feature Service on ArcGIS Online.
One of the layers returns a fatal error which terminates my workbench.
Python Exception <HTTPError>: 404 Client Error: Not Found for url: "AGOL feature service details"
A fatal error has occurred. Check the logfile above for details.
What I find really odd is that I can overwrite 3 of the 4 layers contained in this same Hosted Feature Service, but not one of them.
I.e
Bus Service (Hosted Feature Service)
- Bus Stops (updates fine)
- School Bus Stops (updates fine)
- Bus Routes (crashes)
- School Bus Routes (updates fine)
I'm using FME 2017.1.1 Build 17652
Any help would be much appreciated.
  • Nov 21, 2017 12:51 AM UTC
Are you sure that the layer "Bus Routes" does actually exist in the Hosted Feature Service?
kieranodonnell
Participant
Hi Takashi, yes it definitely exists. I can query the dataset, view it in a map, see the data table etc. I can also read from the layer "Bus Routes" using FME and write it to a local File Geodatabase with no issues
laurawatsafe
Forum|alt.badge.img+14
Hi @kieranodonnell, it is interesting that this works for all but one layer in your feature service. Perhaps try deleting the one layer that isn't working from the workspace, then re-importing it using Writers > Import Feature Types, perhaps there's something not quite right with that feature type.
  • Nov 23, 2017 4:01 PM UTC
@kieranodonnell I can recreate the issue and I am checking it out.
