ArcGIS Online Feature Service Reader: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Cannot perform query. Invalid query parameters.'
  • Aug 8, 2019 2:31 PM UTC
  • 5 replies
  • 415 views
I'm following this write-up on how to update AGOL hosted feature layer from file geodatabase feature class. I spent hours on a chat with FME tech support troubleshooting but no luck so far. This is my first experience with FME so I'm not sure what is going on as I followed directions precisely.
The AGOL reader gets stuck after processing 24,000 parcels (30,162 total) and throws the error. I'm demo the software so its the latest version.
  • Aug 8, 2019 2:42 PM UTC
Some more details:
Log_Error400.txtUpdating_Parcels_AGOL.fmw
bruceharold
Forum|alt.badge.img+20
  • Aug 8, 2019 3:11 PM UTC
Hi, please convert your reader to a FeatureReader & custom transformer and add a loop from the rejected port to the input. Put a Decelerator between the Rejected port and the loop with 5 second delay. Also please log a support call with Esri.
  • Aug 8, 2019 3:33 PM UTC
I should probably mention that I tried different feature class (only 243 features) with the same FME workflow and it worked. So I'm not sure if error message is related to number of processed features
  • Aug 8, 2019 5:59 PM UTC
Update: I stripped the feature class to 21,392 features and FME workflow now runs as it should. This is probably ESRI related, I started the case
bruceharold
  • Aug 8, 2019 8:07 PM UTC
If you can invite the analyst to your org it will help a lot. You can ask they talk to me too.
The analyst will probably ask you return the service to the breaking state so it can be reproduced.
