ArcGIS Online Feature Reader 400 Error
  • November 10, 2017
  • 112 views
I'm trying to read a feature layer and write to a geodatabase. I'm able to connect to my feature layers but I get the following error when running the process
ArcGIS Online Feature Service Reader: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Cannot perform query. Invalid query parameters.'. Details: 'Unable to perform query. Please check your parameters.'
trentatsafe
  • November 10, 2017
Hello @afhughes
I was able to find a past instance of this error occurring, that was addressed in a new version of FME 2017.1.1. Are you currently using FME 2017.1.1 B17645 or newer? If not, are you able to install the latest version of FME 2017.1.1 found here: https://www.safe.com/support/support-resources/fme-downloads/
I suspect this may address the issue. Let me know if that helps.
  • November 13, 2017
I'm currently using 2016.0 so will update and try again, thanks
