ArcGIS Feature Service Reader to Excel Writer missing feature tables
  • May 8, 2024
  • 27 views
michael_v307
Participant
Forum|alt.badge.img+4
I had a FME scenario running to read the feature service and related tables and write to an excel file. I have the excel writer setup to “Fanout” the dataset which used to drop each table from the feature service into its own sheet within excel.
I went back to run the FME scenario and when I check the excel outputs some of the tables are missing. Prior to running the scenario I check to make sure all the tables are checked and that the reader is seeing all of the tables, which it is. I check “select all” and run the scenario but when I check excel I get 6 of 9 tables. I have double check every setting and even started a new FME template and recreated the reader/writer but I still don’t get all the tables in the excel output.
Can anyone help me out?
Thank you
nielsgerrits
Forum|alt.badge.img+64
Hard to say without more info.
Any warnings or errors in the log?
Do all related tables in the feature service have records? If no records, no worksheet is created.
