After Upgrading ArcGIS from 10.2.2 to 10.3 FME fails to run any workbench and shows this massage.
“Unable to perform licensing related tasks. Please ensure that ArcGIS is correctly installed
... Last line repeated 2 times ...
|ERROR |
|ERROR |
A fatal error has occurred. Check the logfile above for details”
Is this means that FME desktop 2015 doesn’t support ArcGIS 10.3?? because form the massage it shows that the FME 2015 Do not recognize the ArcGIS 10.3, Have any one upgraded to ArcGIS 10.3 and face the same problem ?
Regards,
Ahmad
