AIXM / GML writer: How do I write polygons as GM_Ring{GM_Curve{GM_LineString{}}} instead of GM_LinearRing
  • Jul 8, 2019 2:00 PM UTC
  • 55 views
g_tz
The question basically says it: When writing GML-Geometries via the AIXM 5.1.1 writer, polygons are written as GM_LinearRing instances. How do I write out polygons as GM_Ring{GM_Curve{GM_LineString{gmlPosList}}} instead?
itsmatt
Forum|alt.badge.img+48
  • Jul 8, 2019 2:59 PM UTC
It's possible that the AIXM writer does not support curve geometries. I can see from the documentation that is supports arcs but not ellipses or non-circular arcs ( https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/aixm5/quick_facts_aixm5.htm ).
Perhaps @deanatsafe can help you with this one?
