Hi!
I have a question regarding ArcGIS Online Readers in FME (2017.1.2). I set up a connection to an existing feature service and created the feature types of the reader. After that, the name of the service (but not its schema or configuration) was changed through the AGOL web site. Since FME cannot find the source anymore, I wanted to change the value of the parameter 'Feature Service'. However, this does not seem to be possible. Neither through published parameters nor the Navigator entry itself.
Or there a specific reason for that? Or might it be a bug? What I would expect is the same behaviour as e.g. for a File GDB (change path / change path and update feature types if schema has changed).
Greetings,
André
