After a cell update via sql, the formulas in Excel don't update automatically
  • Feb 9, 2017 4:55 PM UTC
  • 156 views
lau
Forum|alt.badge.img+3
Hi all,
I am updating a cell of an Excel sheet using a SQLExecutor. The update of the cell works fine but I have a formula links to this cell that doesn't update.
I check in Excel and the Woorkbook Calculation parameter is set to automatic.
As I have more than 1000 formulas, I don't want to clik on them and press enter (the only solution I found for now) to update them.
I put in attached the workspace.
Best answer by david_r
As far as I can tell the issue lies with the MS ADO library and not with FME as such. It seems like ADO treats your Excel sheet as a pure database and writes your value into the cell without triggering the recalculation.
However, it seems that if you have your Excel sheet open while you run your workspace, it works. This is probably because the (running) Excel engine receives notification of the changed cell value and acts accordingly.
  • Feb 10, 2017 9:39 AM UTC
lau
  • Feb 13, 2017 10:35 AM UTC
nice workaround! Thank you
