Adding in a custom coordinate system
xingfu07
Hi All,
I’ve tried to add in a custom coordinate system and it just doesn’t work. I’ve restarted my computer twice and the co ordinate system won’t come up in the csmap reprojector.
I would love to use the online webform that has been created, but I am unsure at which username and password is required to log-in. My usual FME doesn’t work.
I’ve created a file in the FME folder in documents and edited both coordinate files in the reprojector folder. This is what I have written below:
# COORDINATE_SYSTEM_DEF PerthCoastalGrid1994     \\
#      PROJ TM                                  \\
#      UNIT METER                               \\
#      SOURCE "spatialreference.org"            \\
#      DT_NAME GDA94                            \\
#      EL_NAME GRS1980                           \\
#      DESC_NM "Perth Coastal Grid 1994"        \\
#      GROUP AUSNZ                              \\
#      PARM1 115.8166666666667                  \\
#      ORG_LAT 0                                \\
#      X_OFF 500000                            \\
#      Y_OFF 3800000                           \\
jkr_wrk
Forum|alt.badge.img+29
  • April 24, 2024
Are you sure the lines should start with: # ?
Looks to me like it's commented out as an example. Could you try removing them?
xingfu07
  • April 24, 2024
Thanks for replying. Tried that and it didn’t work.
steveatsafe
Forum|alt.badge.img+12
  • July 12, 2024
@xingfu07 I’m late to the party and I’m sure you have found the solution by now… but in case you have not or others have the same question...
     PROJ TM                                  \
     UNIT METER                               \
     DT_NAME GDA94                            \
     EL_NAME GRS1980                           \
     GROUP AUSNZ                              \
     ORG_LAT 0                                \
     X_OFF 500000                            \
     Y_OFF 3800000
Note the changes:
  1. No comments (#)
  2. No double \\ just singles \
  3. Last line has no \
Ensure to restart FME after saving the changes.
