Adding a logo to a pdf when using fanout
  • Mar 27, 2013 11:36 AM UTC
  • 5 replies
  • 98 views
Forum|alt.badge.img+54
I have an existing workspace that creates a pdf and inserts a logo by reading a png file and then using a rastergeoreferencer to place that on the page (using page units).
I now want to expand this workspace to create multiple pdfs using the fanout on the dataset. However using the fanout means the raster ends up in a pdf file of it's own due to not having the relevant attribute set. I cannot just set the attribute as it needs to go in each pdf output.
Any bright ideas?
  • Mar 27, 2013 12:21 PM UTC
have you looked at the suggestions in this thread?
David
  • Mar 27, 2013 12:23 PM UTC
Sorry, just realized you were one of those answering in the thread I was referring to!
Have you tried using a RasterBandCombiner to combine the logo and the underlying raster into a single raster feature before the fanout?
David
  • Mar 27, 2013 1:27 PM UTC
The logo position on the page is set using page units rather than mapunits. As the raster background is not at a consistent scale I think it would be quite complicated to combine the logo with the background mapping. I'm still not sure how it would be possible to place the logo on all 15 raster backgrounds (15 rastergeoreferencers?)
  • Mar 27, 2013 1:53 PM UTC
Could you perhaps use a Cloner to create 15 copies of your logo, then use the Copy number attribute to assign them their corresponding fanout values?
David
  • Mar 27, 2013 2:00 PM UTC
Perfect, the cloner was just what I was looking for.
