add new empty line in text file specific location
  • Jul 3, 2018 9:17 AM UTC
  • 5 replies
  • 112 views
Trying to figure out how to add an empty line (commas are fine) into a file at specific locations
here is an example i need:
10-1110011-1220012-1310013-14400
Any thoughts?
Regards
  • Jul 3, 2018 10:25 AM UTC
What is the criteria to determine where an empty line should be added?
  • Jul 3, 2018 11:19 AM UTC
the above example is time based so where it moves from AM to PM a break in the data for easy readability is required.
Thanks
  • Jul 3, 2018 1:16 PM UTC
Hi @fme_it, there should be several ways. Just an example.
Set the runtime order at the Passed port appropriately (first to AttibuteCreator, second to Junction).
  • Jul 3, 2018 6:04 PM UTC
Thanks for the suggestion. It almost works, occasionally it comes out before the line but only once or twice.
Regards
  • Jul 3, 2018 10:39 PM UTC
Regards
I think that the workflow inserts an empty line before every text that starts with "12". Wasn't it what you needed?
