Accessing multiple shape files from a zip file and writing to multiple feature classes
  • Dec 22, 2017 12:49 AM UTC
  • 101 views
Could you please help me on how to read a zip file which contains multiple shape files and write to a multiple feature classes.
Cheers,
Srikanth Dasari
Best answer by takashi
Hi @kanthsri74, you can just select the zip file as the dataset for the Shapefile reader, if you have a single zip file that contains multiple Shapefile files without sub directories.
If the zip archive has directory hierarchy within it, follow @TiaAtSafe's suggestion.
fmelizard
Forum|alt.badge.img+22
  • Dec 22, 2017 1:02 AM UTC
Hi @kanthsri74, see this similar question on how to read files from a zip file. For writing multiple feature classes, a dynamic workflow will help you.
  • Dec 22, 2017 1:10 AM UTC
