ACAD Blocks to IGDS Symbols
  • Apr 17, 2018 8:34 PM UTC
  • 37 views
I have an autocad file with blocks that have rotation angles (flow arrows for example). I need to translate to igds and retatin the angle.
ryanatsafe
Forum|alt.badge.img+11
  • Apr 17, 2018 8:40 PM UTC
You can use an AttributeExposer to expose the autocad_rotation format attribute.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/acad/Inserts.htm
Then use the DGNStyler to set the rotation.
