A little help exposing attributes in a JSON
  • Apr 17, 2024 7:46 AM UTC
  • 551 views
j.m-visma
Forum|alt.badge.img+5
I am making a call to an API and getting a JSON in return. With the JSONFragmenter and it's flattening options, I can expose most of the attributes in the JSON into FME attributes, but I am getting stuck on a particular structure. Sometimes there's a little table within a single attribute in the JSON like so:
"related_objects": [
                        "relation_name": "verbinding",
                        "relation_id": 1,
                        "objects": [
                            "randomid1",
                            "randomid2",
                            "randomid3"
This indicates objects that are related in a particular way to the object in my query. I would like to generate a list of all of the related objects (randomid1, randomid2 etc.). I want to use that  list in my FME flow. The number of related objects might be one, or a hundred, in this case it's three.
How do I make FME turn that little array of three related objects into a list?
I include a slightly edited version of the whole API return.
Best answer by david_r
Try something like this:
Result:
You may have to modify your JSON query above so that it matches your exact JSON document.
  • Apr 17, 2024 8:01 AM UTC
Result:
j.m-visma
  • Apr 17, 2024 8:32 AM UTC
Thank you david_r that works!
