3D Solid geometry errors
  • Nov 15, 2025 8:29 AM UTC
  • 151 views
couch
Forum|alt.badge.img+7
Trying to use a clipper for 3d intersections but some 3d solids getting rejected i think due to geometry errors in 3d solids. I have ran the 3d solids through geometry validator but does not fix the geometry errors. Geometry errors include - Non-Planar Surfaces, Incorrect Solid Orientation, Invalid Solid Boundaries. Any other ideas to fix? Thanks
j.botterill
Forum|alt.badge.img+69
  • Nov 17, 2025 12:16 AM UTC
GeometryValidator is the main tool for identifying and sometimes fixing 3D solid errors, but it doesn’t always repair complex issues like non-planar surfaces, incorrect solid orientation, or invalid solid boundaries
  • SolidBuilder may help reconstruct valid 3D solids from surfaces and potentially fix geometry errors.
  • RebuildSurface to repair non-planar or invalid surfaces before reconstructing solids
Check the parameters in these transformers for options like “Force Planarity” or “Repair Geometry” to target specific issue
couch
  • Nov 17, 2025 10:04 AM UTC
Thanks, I take it to turn to surfaces you need to de-aggregate using deaggregator - however this wont occur even if i flatten all levels and split composites.
