1:n with FME, using external Excel file?
  • February 10, 2014
  • 8 replies
  • 29 views
Hello all,
I've got the following table:
Building_ID, Color, Size, Roof
1,Red,1-10m,Flat
1,Blue,30-40m,Tiles
1,Green,20-30m,Flat
1,Red,20-30m,Tiles
Now, I also have this related table which I want to populate:
SubBuilding_ID,Item_ID,Subitem_Work,Subitem_Amount,Subitem_Units,Subitem_CPU
I want to populate this using the following external file:
Work_ID,Color,Size,Work,Amount,Units,CPU
001,null,1-10m,Paint,10,Liters,5
002,null,10-20m,Paint,10,Liters,5
003,null,20-30m,Paint,30,Liters,5
004,null,30-40m,Paint,40,Liters,5
011,Red,null,Flat,Flat Roof,100,m2,10
012,Red,null,Tiles,Flat Roof,1000,pieces,2
011,Green,null,Flat,Flat Roof,100,m2,8
012,Green,null,Tiles,Flat Roof,1000,pieces,1.50
011,Blue,null,Flat,Flat Roof,100,m2,6
012,Blue,null,Tiles,Flat Roof,1000,pieces,1
Now, I can get multiple Work types per Building, so I've got a 1:n relationship. The Excel layout is still up for debate, so it can be changed.
I just can't find out how I would build rows using the external Excel. FeatureMerger is not an option, since it's 1:1...
How would I go about building actual rows in this issue?
Thanks in advance.
fmelizard
Forum|alt.badge.img+21
  • February 10, 2014
If you specify a list name and set process duplicate suppliers to yes, the FeatureMerger will relate 1:M. optionally you can use the Joiner.
  • February 10, 2014
The external table looks to consists of 2 tables in fact. That is, the 1st table defines attributes which should be specified based on "Size"; the 2nd table defines attributes which should be specified based on "Color" and "Roof".
How about dividing the table into 2 tables? I think the Tester can be used to divide the table by determining if the second column is null.
You can then merge each table to the building features with FeatureMerger separately.
Takashi
  • February 10, 2014
Hey Itay, that sounds good! Just thinking how I'd populate the list name using the externa Excel...
Takashi, the thing is that the provided tables are an example, the "test attributes" can go up to 20 attributes to "map" the values.
  • February 10, 2014
Worked out the tables a bit more, and also, for info how the external table should be filled:
Table Building
1,Red,1-10m,Flat
2,Blue,30-40m,Tiles
3,Green,20-30m,Flat
4,Red,20-30m,Tiles
External Excel
012,Red,null,Tiles, Tiled Roof,1000,pieces,2
012,Green,null,Tiles, Tiled Roof,1000,pieces,1.50
012,Blue,null,Tiles, Tiled Roof,1000,pieces,1
Subtable Work (parent Building)
SubBuilding_ID,Building_ID,Subitem_Work,Subitem_Amount,Subitem_Units,Subitem_CPU
1,1,Paint,10,Liters,5
2,1,Flat Roof,100,m2,10
3,2,Paint,30,Liters,5
4,2,Tiled Roof,1000,pieces,1
5,3,Paint,40,Liters,5
6,3,Flat Roof,100,m2,8
7,4,Paint,30,Liters,5
8,4,Tiled Roof,1000,pieces,2
  • February 10, 2014
I would use 2 FetureMerger in this context.
1) Divide the flow of building features into two streams.
2) Merge Work_ID 001-004 to 1st stream (FeatureMerger 1: Join On "Size").
3) Merge Work_ID 011-012 to 2nd stream (FeatureMerger 2: Join On "Color" and "Roof").
4) Send all the Merged features to same Sorter; sort features by Building_ID and Work_ID. Then append SubBuilding_ID with Counter.
  • February 10, 2014
Well the thing is still that the Excel could be using ~20 columns to merge on. The Excel is still free to change, to whatever would work better.
The biggest problem lies in making multiple objects from 1. What Itay said would be awesome, but could I use the Excel as some sort of "tester" and populate a list with it?
fmelizard
  • February 10, 2014
if you merge the features correctly, you can then explode them into multiple features ( "making multiple objects from 1")
  • February 11, 2014
If two or more work types use the same join key, a FeatureMerger can merge them to buildings with "Process Duplicate Suppliers" option, as Itay mentioned.
But different key needs different FeatureMerger. In the example you posted, there are two work types, and they use different keys ("Size" and "Color + Roof"), so I think two FeatureMergers will be necessary.
If a FeatureMerger merged multiple work types (i.e. "Process Duplicate Suppliers" option), the ListExploder can be used to create N rows from 1.
