Write to multiple sheets to the same CSV file, but data is coming from 2 difference sources/streams.
  • Jan 9, 2023 9:36 PM UTC
  • 7 replies
  • 2169 views
As the title implies, I have a workspace where two different workflows have to write to the same CSV but different sheets. How do I go about doing that? I've attempted to use fme_feature_type as CSV File Name but that resulted into 2 separate CSV files as depicted by the image attached
Screenshot 2023-01-09 143608
Best answer by f.kemminje
copy the writer feature types. make it two.
and change the shaeetname. concatenate _1 or _2 (to the sheet name attribute )for the second sheet
dustin
Forum|alt.badge.img+36
  • Jan 9, 2023 9:49 PM UTC
CSV does not support multiple sheets/tabs. Could you use XLS?
  • Jan 9, 2023 10:10 PM UTC
Thanks for the information about CVS. I just tried an XLS writer but this time, the two streams simply combined instead of creating different sheets.
f.kemminje
Forum|alt.badge.img+11
  • Jan 10, 2023 4:31 AM UTC
@Mario Federis​ or use dynamic workflows as described here
  • Jan 10, 2023 7:36 PM UTC
@markatsafe  Are you referring to this subset of the article (https://community.safe.com/s/article/dynamic-workflows-destination-schema-derived-from). I think I understand the general concept of having the destination read schemas from multiple sources. But could you give an example of how writing multiple sheets into the same excel can be done?
  • Jan 10, 2023 9:42 PM UTC
Makes sense. But definitely not intuitive.
f.kemminje
  • Jan 11, 2023 11:24 AM UTC
here is the sample workbench.
