Write multiple files in a directory
  • November 2, 2018
  • 161 views
Hi all.
I am trying to read a directory with many TIFF files, select the latest ones and copy or move them to a new directory.
I read the files with a Feature reader using the Directory and File Pathnames format.
The files got the date-time in the name so I use the Sorter to find the latest one and then I use the Sampler to select a few of them.
Can someone advise me how to write them now in another directory?
Many thanks
Best answer by redgeographics
Try the FileCopy writer.
Forum|alt.badge.img+62
  • November 2, 2018
Thank you for the quick response.
I did that and the translation was successful but the directory is empty.
this is the situation...
It worked!
Thanks!
This also helps https://blog.safe.com/2013/07/fmeevangelist117/
