Visual arrangement of Autocad blocks attributes one over the other
  • October 19, 2022
  • 34 views
dor1411993
Forum|alt.badge.img+5
Hello!
I have workspace which takes shp files and write it down to dwg.
So far so good, FME 101.
The autocad contains manholes blocks with attributes, And in crowded places, where there are many manholes, everything is a terrible mess:
big messIs there a way to do a visual arrangement using FME?
Where the table of attributes hides another table, or is on a sewer line, move it to another nearby place.
I have quite a bit of experience with work intergate Cad & FME,
And here I don't even know how to begin to address it.
I would love ideas for those who have!
Thanks!
I am attaching an example file.
JennaKAtSafe
Forum|alt.badge.img+8
HI @dor1411993​, I am not a AutoCad guru by any means, but when it comes to styling DWG within FME you can use the DWGStyler. Hope this helps to get you started.
dor1411993
  • October 27, 2022
Hi @jennaatsafe​ ,
Thanks for your answer!
But i think that we need smonting more sophisticated than the DWGStayler..
