I need to publish a workspace into FME Server that has a disabled connector and disabled transformer. In FME Desktop 2021, the workspace can run successfully with these disabled. If I publish this workspace to FME Server 2021 and create/run an Automation, will FME Server recognize the disabled connector and transformer and not run them?
Using workspace with disabled connector and transformer in an Automation
Best answer by hkingsbury
Yes, FME Flow (Server) will recognise you have disabled transformers/connections
