Using Email trigger message in a Workspace
  • November 15, 2022
  • 104 views
dms2
Forum|alt.badge.img+11
It's been a while since I last used FME and now it's time to start working with automations  seriously. I need some help to get a quite simple one working though.
I'm attempting to do the following: whenever an email from a certain email address and with a certain concept in the subject is received, the email subject and body must be checked and parsed to write a temporary json file that will be uploaded to a server via sftp overwriting the existing file.
I already have:
  •  An email trigger with a Subject filter.
  •  A 'Sent from Address' filter action.
  •  A workspace action: AttributeManager and JSONTemplater transformers and a JSON writer get the important information from the subject and content of the email into a json file that is written to FME Server temp directory.
  • An SFTP Directory external action: reads the json file from FME Server temp directory and writes it to a server.
The problem is that we are waiting for imap access to be enabled on the email account so I cannot test the email trigger to see  how will it output a message and decide the approach to read it inside the workspace.
I enabled email.subject, email.body and email.from event keys for the  success port. Will the message be a json string or will it be written as a json file inside fme server resource directory? Will it be something like this maybe?
"email.subject": "...",
"email.body": "...",
"email.from": "..."
Thanks.
Best answer by redgeographics
If you set up user parameters on the workspace that processes this you can simply pass the values on.
Screenshot 2022-11-15 at 16.20.03If you want to try this for yourself, the FME Academy module Build Versatile Automations covers this.
Forum|alt.badge.img+49
  • November 15, 2022
dms2
  • November 15, 2022
Easier than I thought.
Thanks @Hans van der Maarel​ .
You're welcome!
