Using attributes from a workspace in FME Flow
  • Jul 4, 2025 3:08 AM UTC
  • 0 replies
  • 54 views
bromp
Forum|alt.badge.img+9
Hi there,
I know it is possible to use attributes from a workspace in a Flow automation by using the automation writer, however that seems to only work if you connect the output port of the automation writer to your next action in Flow. I need a way to use these values in a later event without connecting the port.
Scenario:
Webhook trigger → runs a workspace to create a report that is then stored in a resource folder, also outputs a few attributes that i want to use in the body of my email action.
I then have a resource or network directory trigger that fires when a new file is added, this triggers an email to be sent.
The issue:
If i connect the automation writer port to the email action then i end up with two emails. One contains the attributes in the body but with no attachment. the other contains the attached file but is missing the attributes.
Any help would be much appreciated,
Cheers
