Using an automation trigger webhook as a Teams outgoing webhook?
mtaftferguson
Has anyone configured an FME trigger webhook as an outgoing webhook in Teams? It'd be very nice to just @ an automation without leaving Teams.
I've got an automation triggered by a webhook that can be triggered no problem using curl, but trying to use that webhook in Teams gets an immediate failure ("Sorry, there was a problem encountered with your request"). It looks like Teams may be expecting a particular response (https://stackoverflow.com/questions/45743782/custom-bot-always-replies-with-an-error) and I'm not sure whether FME provides that / how to troubleshoot from here.
Hi @mtaftferguson​ ,
I haven't personally tried to use outgoing webhooks with MS Teams, so someone else may have actually done this and have better advice.
It's a bit hacky, but instead of giving MS Teams the webhook url from automations, you could point it to a Data Streaming workspace url, then have a really basic workspace that creates a JSON response (like in the SO thread) and streams it back to Teams.
You'd also probably need a job submitter transformer or a HTTPCaller to actually pass on the incoming message from Teams to where you wanted it to go next.
mtaftferguson
  • April 12, 2021
That's an interesting idea that I'll definitely look into, thank you! That could be nice regardless; it'd spare us having to change configuration on the Teams side every time we had a new workspace/automation we wanted to use this pattern for.
The automation that prompted this question a beast, so I'd be looking to trigger it, rather than a single workspace/job... there's no automation equivalent of an FMEServerJobSubmitter right now, correct? I suppose that's where an HTTPCaller + webhook trigger would come in.
Edit to add: In initial testing, the data streaming workspace never gets triggered either, so Teams is either interfering sooner than that or it's user error :)
