Use HTTPCaller to download file, to use in my workflow
  • May 10, 2023 2:22 PM UTC
  • 9 replies
  • 1038 views
I want to create a workflow that downloads a file from the internet (SHP file compressed as ZIP file). That file should then be used in my workflow for further analysis and processing.
How should I set that up? I now have a "Creator", followed by a 'HTTPCaller'. This HTTPCaller downloads my ZIP file (contains a SHP file). How can I now use this data for further processing? When I use a ESRI SHP File Reader, I can't seem to send this file as an input to that Reader?
tomfriedl
Forum|alt.badge.img+14
  • May 10, 2023 2:48 PM UTC
You can use the transformer FeatureReader to read your SHP-File after download.
hkingsbury
Forum|alt.badge.img+73
  • May 10, 2023 8:48 PM UTC
Also make sure your are saving your response body to a file/folder. The path you pass to the FeatureReader will be the "_reponse_file_path" attributeimage
geomancer
Forum|alt.badge.img+69
  • May 11, 2023 6:04 AM UTC
If you don't want to save the response body permanently, insert a TempPathnameCreator before the HTTPCaller. Store the downloaded zip file in the path created by this transformer. That way, the downloaded data will automatically be removed at the end of the workspace.
TempPathnameCreator_HTTPCaller_FeatureReader
  • May 11, 2023 6:26 AM UTC
FeatureReader does the trick! That's an awesome transformer. Thanks.
  • May 11, 2023 6:27 AM UTC
Good tip, thanks, just what I needed.
Great suggestion too. Learning so much today!
itsmatt
Forum|alt.badge.img+48
  • May 11, 2023 7:43 AM UTC
Depending on how you are getting the URL you can also just read directly from a URL in either the feature reader of normal reader.
  • May 11, 2023 8:25 AM UTC
thanks, will keep that in mind, i might need that
hodsen96
  • Mar 13, 2025 5:30 PM UTC
When I do the same, I end up having to expose the attributes after the feature reader using an AttributeExposer, is that intended? Is there a setting in the feature reader i should be utilizing to avoid this?
