Uploading ZIP files via webhooks
  • Dec 22, 2025 3:45 AM UTC
  • 130 views
venkateshseru
Participant
Need support in uploading the ZIP files to an FME Flow Resource folder first (via REST API v3 and v4), then pass the resource path as a parameter in the webhook call. The file uploads should accept both file formats zipped and unzipped (single gdb file or package files in a zip).
skyleratsafe
Forum|alt.badge.img+9
Hi ​@venkateshseru,
You should be able to use this REST API V4 endpoint to upload zip files to the target Resource folder. Please feel free to give it a try and see how that goes.
fmeapiv4/resources/connections/connectionName/upload
Cheers,
Skyler
danilo_fme
Forum|alt.badge.img+58
  • Dec 29, 2025 1:34 PM UTC
Hi ​@venkateshseru,
Cheers,
Skyler
Nice job!
  • Jan 5, 2026 8:08 AM UTC
Check the REST API V4 documentation for the endpoint mentioned by ​@skyleratsafe:
https://docs.safe.com/fme/html/fmeapiv4/docs/index.html#/resources/upload_2
And the corresponding method for V3 (attention, will no longer be available starting with FME 2026.1):
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/resources/add_0
